HF 44" Cabinet Lubrication?
Provincial
Near Salem, OR
I bought a Harbor Freight 44" cabinet at the parking lot sale. It has grease on all the ball bearing slides and the casters roll easily, but I haven't loaded it up yet. Has anyone determined if the factory lube is adequate or if I should clean and lube everything with a good grease? :headscrat
basspro
In the sticks, WI
Honestly, linear bearings and toolbox slides alike should use a lightweight oil, something to more or less keep the slides clean while providing a thin film of lubrication.
TiredDude
Louisville, KY
I don't think it is necessary unless you have reason to believe the factory lubrication was not done properly. Mine slide fine. If you do lube, I have heard garage door lube is a good choice.
nicksnothereman
In the Mojave
A lot of people on here don't like "dirty" tools (or chests). If you don't mind go for it. I go nuts with the mystik on just about everything because hey, it's cheap and I don't want to do it every week. But it will make a mess.
P
Provincial
Near Salem, OR
Thanks for all the replies! Since no one has reported a bad experience with the factory lubrication, I guess I'll leave well enough alone.
