HF air saw
Itsahobby
Western Oregon
Hi all,
Thinking about picking up a HF air saw and was wonder if you can use other brand names in them?
I know the quality is not the best, but I "may" only need it for one job. I'm cutting part of the floor board out of a 64 chevelle.
Thanks,
Jerry
TheGrooveking
An alternate reality in a parallel universe.
I had one, it would lock up as soon as the blade touched anything I tried cutting, wood included, I didn't bother returning it, its somewhere in the upper UP with a .308 hole thru it. ( I save **** that is headache that I had to replace and use them as twrgets for my aggression).
I suggest trying Florida Pneumatic, I ended up buying the IR unit and both of Matco's air saws.
TheGrooveking
I
Itsahobby
Western Oregon
"its somewhere in the upper UP with a .308 hole thru it. ( I save **** that is headache that I had to replace and use them as twrgets for my aggression)."
Cool another shootest. :)
Ru2slo_99
I had the same luck as TheGrooveking with my HF air body saw. I would not cut anything without stalling.
nine4gmc
Dallas
I've had two HF air saws over about 16 yrs now, the first one lasted me about 10 of those, the second I have had ever since and it works fine. You need to oil them regularly and use a 3/8" hose with lots of air or they will starve/bog down. I can not count the rear decks and door panels I have butchered with them. YMMV :3gears:
royesses
I have one in my toolbox. It has the same problem as the others. When it works it instantly stops if it touches anything that needs to be sawed. I only paid $5.00 for it, but its worth much less. Look on Amazon for an IR or CP. They work.
jeeper46
Canton, Mi
I bought one at a local used tool store a while back. I needed something that could fit inside the spring perch bushing on my Model A, and make a slice in the worn old bushing so I could get it out. It did work for that little job, but I haven't had a reason to use it since.
Cope
Houston, TX
I bought one thirty years ago and it's still working. It will stall from time to time but overall its good. To answer the question, yes, other brand blades will work with it.
fj5gtx
I have one. It cuts pretty slow, I don't use it at all. I like a battery sawzall better. Ryobi works well, get the Lithium+ batteries. Plus it makes an AWESOME tool for a junk yard run.
fj5gtx
I mostly use the plasma when I can, its one of my favorites. I bought mine in 2001, still going strong. Bottom shelf on the cart pictured...
Yeah I know... a bit more than the HF saw...
chilly460
Similar experience here, mine will just "stall" even without being in a cut. You have to bump the blade to get the piston to turn over, then it'll cut for a bit but stalls frequently. Royal pain in the ***. This is definitely one of those deals where you should go for a more quality unit.
I
Itsahobby
Western Oregon
Order the IR 429, $73 and some change, delivered.
Thanks for the input
Jerry
Sent from my SAMSUNG-SM-G900A using Tapatalk
finn
The UP, God's country
Mine is useless. Binds just looking at a floor pan.
Concept still intrigues me, so I'm looking for experiences with other brands.
Keyblazer
Irvine, CA
Like Zeke, I bought one on sale... Later found that didn't work... Thought I got a bad one, so, bought another ... Now I have 2 bad ones!
Is it an air volume issue?
Mazdaratti3
Connecticut
Mine couldn't even handle cutting one post on my plastic grill on my truck right out of the box... took more satisfaction spiking it on my garage floor than returning it!
maxpower_hd
Massachusetts
I had one that worked OK. It was on sale and did the trick but it broke after a few uses. I ended up buying a Porter Cable as a replacement and it is much better.
