RangerDaleXp
I jumped on the wagon too and got both the ½ and 3/8 impact guns. Thanks for the heads up. I’m a hobbyist so will probably never need another for wear reasons or even upgrade from all the positive posts I am reading. I am now thinking about the ratchets before there all gone. So; pardon my ignorance when asking for what or when you would you grab for the 3/8 or ¼ ratchets. They don’t feature a hammering action for breaking loose tight bolts do they? I’ve never used one and am looking for the applications when you would grab these. It makes sense to me to use if you had a ton of fasteners to loosen or tighten in a single sitting all of the same size; a situation I would probably never encounter. Just curious; sorry if I am over thinking it. Thanks
I use the 1/4 on small stuff like transmission work and anything in the engine area like most water pumps, Valve Covers. I guess anything 1/2 size socket and down. 3/8 I would say anywhere from 1/2 to 7/8 socket size like maybe alternator brackets, shocks, brakes and so on. I also have a 1/2 inch for anything over 7/8 on an inch.....
I look at it on a per job bases on what to pull out of the roll away versus the job at hand....
