HF have electric hole knockout set
jw3
I’m pretty sure, but I think it’s for iron pipe sizes
sberry
Brethren, Michigan
I really only need them to 2 inch. I have some smaller ones and my neighbor has them,,,, its something I should have got a long time ago. I use them only occasionally, did one the other day with holesaw. I really don't need hydro. I see Southwire at Lowes for 250$ and if I had several jobs in the wind would go for it but I am dam near penniless now, tool rich in most areas as it is.
sberry
Brethren, Michigan
I got them to inch, the first kit would give 1 1/4 which I need and the hydro kit is a steal. I looked at HF this morning on phone and couldn't find it. It doesn't seem to indicate if they have a way to check store stock.
shanny19
PNW
What sizes do you think knockouts are? They're all IPS.
He might be confusing knockouts with the whole dimple die issue.
Dimple die sets come in two flavors, nominal round numbers for use with tubing, OR sized to fit pipe.
Lots of guys get the wrong set for their application, and consternation ensues.
sberry
Brethren, Michigan
I did manage to find a 1 1/4 that I had and misplaced. That's a start. Next time I got a real call for the larger ones I think I am going to score that HF hydro.
manwithtools
Lebanon, TN
Just get the Milwaukee and enjoy the rest of your life: https://smile.amazon.com/Milwaukee-2677-21-FORCE-LOGIC-Knockout/dp/B01BMVZQHW?sa-no-redirect=1
I found one for just under $900, the ease of use is beyond description. It's nothing like a hydraulic Greenlee or Enterpak, no fighting hoses, quick, precise and effortless. Our guys love it.
You position the punch and die and THEN attach the powerhead. It's so easy to position the holes exactly where you want them, it's a pleasure to use.
davidgreams
Foster City
I looked at that. The Harbor Freight knockout punch has some bad reviews on durability, with some users complaining about even the first few punches.
If you go that route, it might be worth the investment in a Greenlee punch - and then sell it on eBay if you don't need it anymore.
The other thing to think about with knockout punches is that conduit punch sizes are not a 1:1 correlates to hole size. For that, you need a radio chassis punch.
If you go with a step bit again, I learned from BobbyfromNJ's YouTube channel that the trick is to drill the last step from the inside of the kettle outwards.
Even with that, it took me about 10 minutes with a file (and earplugs) to deburr and smooth the hole to my satisfaction.
sberry
Brethren, Michigan
I had the tin man secret weapon, hi leg av snips. Knocked it out to 1 1/4, draw around the fitting with a marker and maker 3/4 circle cut after I loosened the box from the wall some. Took me about 10 minutes. If it wasn't already installed, full of wire and on the bench it would have been super easy.
sberry
Brethren, Michigan
Once I figured out how it took only a couple minutes. I see my brother bought another set of the snips in straight. These are Milwaukee. I found them today, havnt had a chance to use them.
sberry
Brethren, Michigan
I found another set of snips today my brother must have bought, straight made by Milwaukee. These are straight, I have a right and was looking for a left. Once I figured out I could do this it took a couple minutes.
