looks really thick in those pics for a low profile. maybe the angle or the flash? i havent put my hands on one yet.
They should come out with a stright 1/4 and 1/2 drive composite like they did with the 3/8 drive.
It looks like eventually they will offer a 1/4" and 1/2" in the new style composites according to this pic. The part #'s don't come up with any results when searching their site though.
The push button ratchets are nice, I have the push button composites, and the 1/2 extendable. However adding a quick release button to a low profile ratchet defeats the purpose. If the confines of the space you are working in calls for a low profile ratchet, the last thing you want is the push button being depressed and possibly losing a socket in an already confined environment.
None of the truck brand low profiles I have seen have a quick release button either....
How do u like the extendable? I was thinking about picking it up too.
you can't switch you need them all. The red and black composites are longer than the othersIts my go to ratchet for alot of tasks including wheel lug nuts, crank bolts, clutch hub nuts, basically anything that is torqued to over 50 ft lbs. It just makes things easier, and as a bonus it takes less room when put away.
I also like the new style Red/Black composite ratchet and will wait until I can get a matching set before I decide if I am gonna switch from my Grey/Black composites.
All three sizes are available at my HF. I plan to keep these in my trunk because even in the deep cold they won't be as frosty as my metal ones.
My local HF only has the 3/8 drive in red/black
Guys i have the 1/4 flex, 3/8 flex, long 3/8 flex/ long 1/2. Out of those ratchets the only 2 i have not had issue with was the 1/4 and 1/2. The issue is if you put any kind of toquor on them the head gets super floppy and you can strip out the torx screw i have replaced the 2 3/8 at least 5 times. I am a auto mechanic for a living. Now the head of the ratchet is amazing. All metal insides solid head just the handle where the ratchet head sits in *****. I am trying to find a way to fix this. because i cant afford snap on or matco. I have to use what I can afford.
Didn't somebody already post a solution to the floppy head?
Using a washer, or grinding the shoulder off the bolt or something.
