HF powder coat system.
daddycreswell
Middle Tennessee
Looking to expand my stainless steel cup business, by powder coating them with decals on them. Anyone here have the HF PC system? I think it would be pretty good for a novice. Thanks
Maverickv46
SW Michigan
First post on here, so dont discredit my advice based on that!
I would urge you to stay away from the HF system. I know of a few people who bought with the intention of doing their own parts and end up throwing it away and using me. (Granted, some of them probably just dont want to do the work)
Instead, at a minimum I would start with the Eastwood system. It is what I started learning and my business on a few years ago and it can turn out decent work. That system still stays in the shop when I dont want to prep the nicer NitroFaze for a color sample or non cosmetic part.
Eastwood original $79.99 (potentially cheaper not on their site)
Eastwood Dual Voltage $107
ichabod
minnesota
I agree with Maverick. I have been using a HF one for home projects. soon to be upgrading. but I am now use to the HF coater and can get ok results from it, now I am just an amateur and only do my own stuff. depending on what size projects you are doing, the oven will be a major concern. when I did this fire hydrant the kitchen oven just was not going to do it.
good luck powder coating is addictive.............
maxpower_hd
Massachusetts
Did you powder coat the troublehead too? LOL Nice looking bike. My buddy has one that has a similar look but it's a mid 50's hardtail frame instead of a swing arm. His is kick only. But his does have a 1983 engine.
Oh and the fire hydrant looks good too. LOL
happymachinist
Central NE
I would also suggest at minimum the Eastwood setup. If you can swing it the dual voltage.
I've had mine for ~7 years and it's done almost everything I need it to, but I struggle with second coats on some parts and have to hot flock it. If I knew the dual voltage gun would cure that issue I'd "upgrade" in a heartbeat.
A commercial grade setup isn't practical for my hobby applications.
Sent from my XT1254 using Tapatalk
Maverickv46
SW Michigan
Are you running a dedicated ground rod for your parts? That was a huge improvement in multi coat ability with the EW gun.
D
daddycreswell
Middle Tennessee
Picked up the dual voltage Eastwood gun yesterday on the daily deal for 107.00
Maverickv46
SW Michigan
Yea, you will get much better results if you drive a ground rod and run a nice 4-6AWG copper wire to your hang rod/rack. Using the ground clip on the control box is doable, but there are a lot of connections and wire between that box, the outlet, the romex, the breaker box, etc.
happymachinist
Central NE
Well, sort of. The landlord of the shop I was renting was against me driving a rod in the corner, don't ask me why, but hey their place, their decision.
So I ran a 6AWG from a pipe that eventually went in the ground but I don't think it worked as well as a rod would have.
Once I get back up and going in my garage bet your *** I'll have a dedicated rod or two.
BADSIX
oregon coast
For more information look up Caswell Plating. there is a good powder coating forum and an oven building forum for hours and hours of reading. its the place to go if your interested in powder coating.
Jay D.
