daddycreswell
Looking to expand my stainless steel cup business, by powder coating them with decals on them. Anyone here have the HF PC system? I think it would be pretty good for a novice. Thanks
Eastwood deal of the day today is their dual voltage powdercoat gun.
before you buy look up coupon codes for free shipping and/or 10percent additionally off.
I agree with Maverick. I have been using a HF one for home projects. soon to be upgrading. but I am now use to the HF coater and can get ok results from it, now I am just an amateur and only do my own stuff. depending on what size projects you are doing, the oven will be a major concern. when I did this fire hydrant the kitchen oven just was not going to do it.
good luck powder coating is addictive.............
I would also suggest at minimum the Eastwood setup. If you can swing it the dual voltage.
I've had mine for ~7 years and it's done almost everything I need it to, but I struggle with second coats on some parts and have to hot flock it. If I knew the dual voltage gun would cure that issue I'd "upgrade" in a heartbeat.
A commercial grade setup isn't practical for my hobby applications.
Sent from my XT1254 using Tapatalk
Are you running a dedicated ground rod for your parts? That was a huge improvement in multi coat ability with the EW gun.
Well, sort of. The landlord of the shop I was renting was against me driving a rod in the corner, don't ask me why, but hey their place, their decision.Are you running a dedicated ground rod for your parts? That was a huge improvement in multi coat ability with the EW gun.
