Hiball, jack storage question
BigE
Central Alabama
Normally, I would have sent a private message, but I thought this would be valuable for all us GJ'ers. I have a few-year-old big, heavy Hein-Warner jack that I'd like to store out of the way. However, its size and heft makes lifting it onto a shelf a virtual impossibility. So I was thinking about flipping it up onto it's wheels (handle up) and using the handle bar to maneuver it against the wall. On that wall, I would have a cradle of sorts that the jack body or wheels would latch into. Then I would rotate the handle up against the wall and lock it into another bracket. My question is: would storing the jack in this vertical position be detrimental to the jack in the long term?
matt_i
SE Michigan
I think as long as the oil doesn't run out of the reservoir (filler, breather) then you can't hurt it. Its metal, O-rings and oil.
rslaback
Westcentral Wisconsin
I made a garage for mine when I was teaching that was basically 2x6 chunks with a plywood top. Now that it is just me at home I roll it under the end of my workbench.
pop pop
Virginia
The worst that is likely to happen is you get air into the pump suction when you use it again. One up and down and it's gone. I don't recall that jack being vented like the Lincoln, so not likely to spill from the reservoir.
