High Flow Air Connectors?
darita
Roseville, CA
I just became aware of high flow couplers and plugs. I love that they have a larger ID for more air flow, however I can't find anyone who makes high flow hose barb fittings to match. All of my hoses came with 1/4" NPT fittings, however their ID is small compared to the high flow connectors.
Has anyone been able to find high flow hose barb fittings?
MattT
Parker makes plugs and couplers with built in hose barbs. And FWIW I wouldn't worry about the inside diameter of the 1/4" NPT hose barbs restricting flow. I personally prefer the fittings with integral hose barbs because they're more compact and one less joint to leak.
rattle_snake
Chandler, AZ
Not all 1/4" barb fitting have same ID. Look at what you have and upgrade where needed. Some fitting can have ID drilled, others not. Some pre-made hoses have fitting with larger ID than easily available barb fittings.
A real 0.250" fitting ID is close to Milton 'V' high flow connector ID.
Just the V connectors are a big improvement over the 'M'. A hose reel will be your biggest restriction.
