fury9
I switched over my fittings because it was all the rage, didn't notice any difference except a drain on the wallet and bigger fittings to get in the way
No problem. Everyone that I recommend high flows to as felt the difference right off the bat like I did. I wish I found them sooner lol
I switched to Milton from import ****. They are much better. No leaks.
All of mine are the same as those pictured.I'm a Milton user as well, but the V style fittings that I bought recently at Northern Tool were made in Taiwan, so Milton isn't all US made.
What do u consider a long hose? I use a 50foot flexzilla and I noticed a difference
... I used to have an extra [pancake regulator] off a compressor. Those things are TINY. There is no way they flow well....
... Before I ever fired it up, I pulled all the plumbing from the tank, and upped the 1/4" stem to the pressure switch with a 3/8" tee, with a 3/8" shutoff valve straight to a 3/8" coupler....
In that case the milton V's that are imported are **** too.
