High flow quick coupler
volleyball
NY, not NYC
I have a bottleneck in my air system. I have a quick disconnect at the compressor and it is a 3/8" NPT to a 1/4 coupler.
So I want a 1/2" NPT to !/2" coupler for my flex line.
I am not too concerned with compatibility with other fittings
I am cheap so nothing too expensive.
What do you recommend?
V
volleyball
NY, not NYC
I saw a pressure washer fitting that is 3/8" but there isn't a valve so it should flow well. $4 for both ends.
MN4x4
Minnesnowta
+2 on the Milton V-series high-flo couplers. I switched everything in my shop over to them.
Nikon_RH50
Northern tool, farm and fleet, amazon. Carquest has them for order only, they use to stock them.
zkdiesel
chicagoland cornfields
Have nothing bit problems with Milton v style. I changed my whole setup away from ten I had so many failures in a year. 8 female fittings needed replacing
cat-mechanic
Peoria, AZ
I run the Oetiker couplers. They are full flow. They just don't meet your cheap requirement.
zkdiesel
What went wrong with the V's? Was it just the gaskets? Want to sell you V stuff?
They would stick opent random and you'd have to mess with them to seal up, or sometimes would blow out full speed and nothing you could do would fix them
Pm me adress and pay for a flat rate box and I'll give you what I have laying around. Some of it may have got **** canned, I'll check tmrw
rustychev
If he dose not take it let me know what you have left I use the v's
Crown Imperial
SE Florida
I guess if they can stand mine duty they must be highly reliable.
Probably have a Deutz engine running the air compressor?
