Some updates!
This April we finished the floor in the garage, which is a huge milestone and improvement from where we started.
Due to budget, usefulness, ease of prep and installation as well as how well the product is proven to hold up, I went with Rust Bullet from Garage flooring LLC
http://www.garageflooringllc.com/rust-bullet-concrete/
Justin and the team at garage flooring llc is fantastic, and their products were perfect for my needs. if you are considering doing a floor on a budget, this is absolutely the way to go. The rust bullet system is straight forward, no fiddling around. just paint and go.
here are some pics of the progress:
We had to diamagrind the floor before we did anything due to the sealer the concrete company put down. If it wasnt for the sealer we woudlnt have had to grind -just powerwash. Rust bullet does not require grinding if a floor does not have a sealer on it.
word to the wise, if you are having a new floor put down and want to finish it do not let them put a sealer down. period. it doesnt matter if they say its a mild sealer or shouldnt cause issues - it likely will. In our case, i put down a few test spots of rust bullet on the sealed floor and then after it cured put down gorilla tape on top. after letting the gorilla tape sit for a day, i pulled it up and found paint on the back - a clear sign the sealer affected the ability of the rustbullet to adhere.
After grinding and power washing a hand full of times we got to a good clean floor, that we could start working on.
the 1st step after our prep was to put down the garage flooring llc TL829 flexible joint sealer to go into the contraction/expansion joints. It is a straight forward two part epoxy and is pretty easy to use, and requires no grinding afterwards as it is self leveling. Just pour it in, and then after it firms up (but not fully cured), you can trim the excess with a razor blade.
TL829 is a flexible epoxy that is permanent, self leveling, and fills in the expansion joints - but it has elasticity so it allows for expansion, contraction and movement. its a perfect filler solution that wont leave your floor cracked or ruined when the floor moves or expands/contracts.
https://scontent-iad3-1.**.fbcdn.net/v/t1.0-9/12994526_10156759310760510_6103839029995349408_n.jpg?oh=16d6f4d56681286b578a5e5405d3ffd6&oe=57CE4D7F
https://scontent-iad3-1.**.fbcdn.net/v/t1.0-9/13043489_10156759310740510_4256762282951450499_n.jpg?oh=3b7ea1ed18377942551ba88b3b8548ad&oe=57CB2296
https://scontent-iad3-1.**.fbcdn.net/v/t1.0-9/13010799_10156759310810510_8113586620942110278_n.jpg?oh=43577b87d4c10f9755e0121e5291eede&oe=57E239D3
typically two coats of rust bullet are enough. we went with four because a)we ground the floor which would require us to use more of the product (ground concrete soaks up more), and b) because we wanted more of an industrial quality flooring to handle anything i throw at it. i say when you have a job to do, do it once and do it right.
first coat
https://scontent-iad3-1.**.fbcdn.net/v/t1.0-9/11219690_10156784574135510_983547837515532444_n.jpg?oh=f76db7a89865b52b0d60316edc4a68ed&oe=57CE46A7
second coat
https://scontent-iad3-1.**.fbcdn.net/v/t1.0-9/13083241_10156785338720510_2698340264396197481_n.jpg?oh=978ffe555efc0df310df0f1e969a5424&oe=57D9DCD0
skipping a head to the fourth coat
https://scontent-iad3-1.**.fbcdn.net/v/t1.0-9/12524148_10156787768000510_3745606908957896547_n.jpg?oh=28311166e54c121ea954a74f044cd115&oe=57C6F6E2
https://scontent-iad3-1.**.fbcdn.net/v/t1.0-9/13043255_10156789302915510_11302076119446138_n.jpg?oh=309e8891b632c348a2d2c0494fbaad45&oe=57DF14CD
pro tips
- use a tyvec suit when you paint this stuff on. also a respirator is a must. (plus the combo makes you look like walter white doing a cook)
-wear rubber gloves!! this stuff does not come off unless you use their solvent.
-if you buy the kit, it comes with solvent. if you piece mail it, do make sure to get the solvent
-if you have a separate entry door to the garage, get plastic sheeting big enough to cover the bottom half of the garage door, and staple in place. this allows you to a) keep the garage door open for venting b) by covering the bottom half, you are blocking enough to help keep dirt and leaves and stuff from blowing in the garage door.
now its the slow process of moving things back in and reorganizing after everything was put in boxes and shoved in the side room of the garage (leanto) for the last 8 mos)
https://scontent-iad3-1.**.fbcdn.net/v/t1.0-9/13096262_10156809752145510_728436522886272616_n.jpg?oh=6d73c5f5f9a76e445d8967ecca80b57e&oe=57DC54B9
