penright
I got my Treatments, Repairs and Replacements. It's an Oklahoma real estate thing. My question is what does the NEC say about this situation .....
"The 60 amp circuit breakers in the heat pumps electrical disconnect box are oversized. The manufacture of the heat pump lists the maximum breaker size at 25 amps. The oversized breakers need to be replaced."
The breaker in the panel is 50amp. I just replaced the FP with a brand new Eaton, by a licensed electrician. Should I replace the breaker with a true disconnect ? http://www.homedepot.com/p/GE-60-Amp-240-Volt-Non-Fuse-Metallic-AC-Disconnect-TFN60RCP/100674085
Also, there was mention in a existing "flush mount" sub panel, wires entering the panel did not have cable clamps or bushing. In googling I found something that looked like it was split and snapped into the hole, like you can do from inside the box. What is this called? I could not find any, assuming they are ok, I may have to find them at the local supply. The sheet rock is unfinished, I can pull it down and remove and replace the wires. Just it would be a lot more work.
