Tracs
I have chosen to install L0-Rib metal siding horizontally on the inside of my 40x60x12 shop. The 40x12 gable wall with the overhead door, entry door, window will be completely done in 1/2" good one side plywood.
So that leaves 3 walls to do.
For the 3 walls (12' 4" tall), the 1st 4 ft will be good one sided plywood, then 8' 4" of the LO-Rib. Which works out to 2 full sheets plus 2/3rds of a sheet.
My question is:
Can that 1/3rd cut off be used elsewhere on a different wall so I can order a few sheets less?
My quick thinking has me ordering 24 - 20' pieces for the 3 walls and that would be cutting about 8" off 8 sheets.
I don't know how the overlaps and factory edges work when installing metal siding.
My question is:
