Horizontal of vertical compressor?
Steevo
43.49600, -112.04300
What advantage is there to a vertical tank compressor over a horizontal one?
I am thinking that I'd like to put my big shop compressor in a corner that would also have pallet racking in the same space, and that a horizontal unit would allow me to have a set of load beams and shelf at about 4.5~5' vs. over 6' with a vertical unit.
larry_g
oregon
For your purpose pick the style that fits. Operationally there is no difference.
lg
no neat sig line
Jack Olsen
Los Angeles
With a non-portable unit, it has everything to do with where you want to put it.
If you're going to roll it around, the horizontal will be less likely to fall over.
hetkind
Johnson City, Tennessee
Verticals are good up to about 10 hp...most units bigger than that are horizontal, often with TWO motor/compressor units per tank. Pick what ever is best for your needs...
Howard
Falcon67
Merkel, TX
I like vertical for a fixed asset, takes up less floor space. Squeezed it into a corner the space between a wall and a storage rack, built a small shelf over it.
nehog
Jaffrey, NH
My horizontal fits under a (tall) workbench. If it was a vertical then I'd have to find space for it!
TLCDino
Pasadena, CA
Two ideas. 1) unless you have plans to build shelves over the thing, horizontals are hard on space. 2) I don't know, but think vertical units handle moisture better. Water collects down at the bottom and is easy to blow out versus along the long flat space of a horizontal.
Here is mine snugged into the corner of the compressor (I mean laundry) room.
Steevo
It does not sound like there are any technical advantages to a vertical compressor, which was what I was wondering.
Given that in my situation, a horizontal is more space-efficient, I think I'll concentrate my search in that area.
Thank you all for your responses.
