Hose clamp nut driver size?
Tawn
Maryland
What are the most common size nut driver for hose clamps? I don't need a full set, just a couple for hose clamps on the boat - I am on the couch and the boat is 12 miles away so I can't just run down and check. I've always used screwdrivers in the past.
I know some are 5/16" but I don't know the others and I don't want unneeded tools taking up space.
Any help would be appreciated.
CJM8515
Get one of those screwdrivers 4 in 1, the one side is 5/16 and the other 1/4 if you remove the bits. Then you also have a screwdriver!
srmofo
SW ohio
I use the grey/yellow, grey/orange, and the clear/red from craftsman. I wanna say 8mm,7mm, and 1/4"
T
Tawn
Maryland
Going to need a pic or two of this one!
I appreciate the info guys. I'll grab a 1/4" and a 5/16" and go from there.
2007 46 Markley
46' long, 14' wide
490HP Cummins
USCG Certified for 17 passengers plus 2 crew
rlitman
Long Island
Worm gear clamps are sized in SAE sizes. They have have metric sizes listed, but they are not metric. 1/4 and 5/16 cover most. 3/8 covers really big stuff. That's it.
Daniel Dudley
I have a six way screwdriver that has reversible flat/phillips drivers on the ends. When you pull out the driver bits, it turns into a 1/4 inch 5/16 inch nut driver.
Very handy tool.
http://www.lutztool.com/6-in-one.asp This is the tool. It does not list the 1/4 nut driver, but it has one.
srmofo
SW ohio
This was not my experience with oe automotive. There are clearly 3 sizes commonly used and 3/8s was not one of them. Now when replacing them, our aftermarket clamps only came in 2 sizes.
DodgeMech
7mm, 1/4 inch, and 8mm/ 5/16 inch should cover damn nearly anything...and maybe bring a medium sized flathead too just in case
sberry
Brethren, Michigan
You need a set in both flavors anyway and the 1/4-5/16 you should have extras. Mainly 5/16 but we use nut drivers for a lot of stuff and have about 10 in 7/16 too. 3/8 was used in a lot of old mfg, furniture etc.
Very handy tool.
OK, I assume the 1/4" hex is just the socket end minus the driver, but where is the 5/6" hex ?
purplezr2
Central MN
Sure about that, I have a bunch of 7mm on my car which a Audi...
T
Tawn
Maryland
Stopped at the hardware store on the way home and grabbed a 1/4", 5/16" and a 3/8" Craftsman. Made in the USA none the less. I also ordered the flexable Tridon driver from Amazon that was recommended.
