Teikas Dad
I searched all the posts I could find here regarding what size heater to get, but couldn't find what I was looking for.
My new shop is 20 X 20. There are two exterior walls with 2X6 framing, R19 insulation and two interior facing walls that are 2X4 framing that are insulated to R13. The ceiling is 10' high with 5/8 drywall and R30 insulation. Floor is a concrete slab with R5 foam insulation on the outside all the way to the bottom of the wood siding.
I found the link to the Heat Loss Calculator and according to that my shop has a heat loss of 5960 BTUHS. I figured a Design Temperature Difference of 50 degrees. That would take me up to 70 degrees if it's 20 degrees outside. I'm in western Connecticut and we do get some cold weather here. Past couple of mornings were 5 and 6 degrees, but the majority of the time it's in the upper teens to low 30's for most of the winter around here.
Hot Dawg's website has a lot of info, but they list 1 to 1 1/2 car garage, 2 to 2 1/2 car, etc. My shop is not a garage so I'm trying to figure how my size fits into their recommendations. I don't want to go too big on the heater as I have read here that using too large of a unit is just as bad as too small of a unit.
Bottom line, I'm trying to figure out if I need the 30kBTU or 45kBTU unit....or, do I need a 60kBTU unit?
