How are these large "split" Snap-On dies used? TD9902B
3jakes
South Central PA
I've seen one of these type die before, now I am flipping this Snap-on set (TD9902B) where all but one die is split with an adjust tension screw.
I'd like to know more about this set before it leaves.
Can someone explain to me how this is used?
How do you know when the correct tension or gap is achieved?
cvairwerks
Within hearing distance of Texas Motor Speedway
If you look at a thread table, it will give you a range of dimensions for a particular thread size and profile. Within that set of numbers is a fit classification. That classification defines the difference between the internal and external thread dimensions. A loose fit means that things thread together very easy, with little effort and can be easily over torqued causing thread damage or vibrated loose under the right conditions. A closer fit changes the values, sometimes for the betterment of an assembly. There are times though, that too tight of a class raises manufacturing costs unnecessarily and can impact assembly. Lots goes into not only thread profile selection, but fit class too when designing something.
red94chev
Northeastern MD
Everything cvairworks said. Here's the basic idea of how to use them.
1. Adjust screw to enlarge the diameter.
2. Cut threads.
3. Test fit assembly to check thread engagement (may not even fit if threads weren't cut deep enough).
4. Adjust screw and re-cut threads.
5. Test again until you get the thread engagement you like for this application.
3jakes
South Central PA
If you look at a thread table, it will give you a range of dimensions for a particular thread size and profile. Within that set of numbers is a fit classification. That classification defines the difference between the internal and external thread dimensions..
Thanks.
As in many things... "one size does not fit all"
In fact... one size sometimes, does not fit itself. :headscrat
3jakes
South Central PA
2. Cut threads.
5. Test again until you get the thread engagement you like for this application.[/QUOTE
Thanks.
larry_g
oregon
http://www.amesweb.info/Screws/AsmeUnifiedInchScrewThread.aspx
The above references the classes of threads. Thread classes are basically how tight the tolerances are and so the split die can be adjusted to set the tolerances you need. In the below link read the three wire measuring procedure or some of the other measuring methods for determining if threads are in tolerance of the class you are trying to achieve. Threads and thread cutting can be quite complicated if you take the time to learn and understand.
https://www.threadcheck.com/technicalinfo/
lg
no neat sig line
2oolhound
BC Canada
I'm not a machinist, engineer etc but I cut a lot of threads and have a few sets of those same dies so this is just my opinion. Info I've gleamed on this subject is the thread classes and Audel's info posted above is too specific for general use and more suited to building intricate precision things with tool steel.
All basic tap and die kits like these from Snap-on, Mac, Hanson/Irwin etc typically are not be made from HSS and will cut threads to 75% nominal dimensions in mild steel. The set you have offers 2 settings, 75% nominal and 60% nominal which is a little looser fit but still very useable for most uses other than high torque applications. The adjustment screw should always be all the way in or out but not in between where it is not locked in position.
If you consider the V shape of a thread and imagine a nut and bolt with the same pitch and dimensions you can see where on paper a single zigzag line would denote the threads for both nut and bolt. However a nut and bolt that shared that same zigzag line for their dimensions would not fit together without a lot of friction. For this reason threads are cut to a percentage of pitch of the nominal size. Aside from this the tips and valleys of the V shape are truncated or chopped off.
When cutting female threads the drill size specified will produce 75% nominal threads. For a 60% nominal, choose the next biggest drill.
For male threads your round stock will be specified (eg. - 3/4", 5/8" etc.) and will yield 75% nominal threads from the die. For 60% form factor you should use undersize round stock which will vary according to the thickness of the stock used but you could use the same dimensions as the next smaller drill size available as a reference on how much to turn down your stock.
rsanter
visalia ca
If I remember correctly, it allows you to set the class fit for the threads.
Correct. The class of fit defines the gap, play, or space between the internal and external threads.
If you thread a shaft and the fit of the nut on it seems a little too tight you can adjust the die and go again.
For 99.9% of the applications if you don’t know what you are doing then leave it alone
colin39
Like button needed,, thank you. It's ok he is on YouTube now watching someone :thumbup:
MShaw
York, Pa.
"HSS and will cut threads to 75% nominal dimensions in mild steel. "
No. the blank size is adjusted to yield a percentage of full thread, Typical threads have the blank size adjusted to provide 70% of full thread when cut to the proper size (Pitch Diameter)
As you get closer to 100% full thread tool life goes down and difficulty of cutting threads goes up. 70% thread has been tested and accepted as providing ease of cutting with minimal loss in strength.
CR888
Are these dies only supplied or offered in high end machinist style tap & die sets? Or would they be something you would order individually as specialist pieces? Interesting thread.
MShaw
York, Pa.
I just realized that the above statement was in error. The tapped holes have the tap drill size adjusted to produce 70% thread. The externally threaded part is produced with the diameter slightly below nominal size. The actual diameter is determined by the class of thread. Sorry for the mis-statement above.
bob15
Northeasten, CT
You typically buy them in singles. McMaster, MSC, the former Enco would be the type of places to buy them.
remember if you buy them, you need to get a new die holder as well.
kelpaso1
MEMBER EMERITUS
New Brunswick
Another question related to this thread. What is the purpose of this adjustable ring thing on my die holder? Some kind of guide? How do you properly use it?
RVDan
North America
Geez my SnapOn guy told me you adjust the screw to open it up when trying to start threads on raw bar stock.
LeeG
Phoenix, AZ
Put the die in the holder so the "feed side" is toward that side of the die holder. Adjust the opening on the die holder so it just fits the stock you are cutting the thread in. This will help in keeping the die in line with the stock while you are starting the thread.
Some die holders can be found with a solid tube for the same purpose, but they are limited to a single die size (or small range).
2oolhound
BC Canada
3jakes, here are photos of some snap-on charts found on my T&D sets you can print. Notice on the bluepoint is states to use the screw all the way in or all the way out but on the newer set it says you can set it in between. I always thought the screw might creep if it was in the middle somewhere. Maybe they reduced the slope of the threads to reduce friction on them.
6PTsocket
What they said. You can experiment but there are go-no go screw gauges that you can set the die with. My metal work is not of a level that I get into class fit but if the bolt seems too loose or tight, I just use a bolt as a screw gauge and set the die so it just stops cutting.
RoyArms
Harbor freight has dies with a split in them as well. Came in handy when fixing the threads on a prop shaft on a boat. Spun the prop off and the steel was too hard to thread a normal hardware store die on, actually broke it trying. Ran the split die on at its loosest setting first and it was no problem to get it cleaned up.
