How can I remove these Bolts??
fruitpieisgoodeatin
I purchased a 2013 Frontier used and a bed rack came with it. I thought it would be easy to remove but I have had no luck. The silver slider rails below the bed rails must be glued to the bed or something because I need to remove those to get to the big bolts that attach the bed rack to the truck.
How can i get these bolts off so I can just remove the rack directly?? Thoughts?
F
fruitpieisgoodeatin
The bolts are not stuck.. Its just that i have no access under to get the nuts off. The silver rail wont budge to take off. Can I rent an angle grinder at home depot and grind those bolt heads off? hacksaw? drill bit?
cvairwerks
Within hearing distance of Texas Motor Speedway
The bolts in the rail are either self tapping or are into rivnuts. Might be some tape behind it too. Probably another bolt behind the end stop. Looks like you have LED’s run on the top of the tracks...there a bolts in that area too.
