How do I adjust a Snap ON split beam torque wrench
DickDeegan
Frankford, Ontario, Canada
Hello. I am a newbie on this site although I have been a member on the Model A Fordbarn site for years.
I have a Snap On Split beam torque wrench which needs adjusting. I have a digital torque adaptor and find that the Snap On Torque wrench is our of calibration. When I dial 60 ft-lbs on the wrench, I am actually getting about 70 ft-lbs. The wrench is 1/2" drive and is about 20 years old and has never been calibrated.
It has two small screw type (about 1/4" in diameter) fasteners on the side beside the dial which I assume are there for adjustment. The fasteners have two small holes in each to allow turning.
Do I just turn these to adjust? Do I remove these and is there an adjustment internally?
Any help will be much appreciated.
rsanter
visalia ca
Look at what the tolerance is for the electronic adapter. Most of the cheap ones have a wider tolerance than the actual quality torque wrenches.
My SO guy has a torque tester attached to the wall of his truck so people can check or verify they wrenches
Send it in for certified testing is the best thing to do
Bob
