oldschoolcraft
I'm not a pro and I never used ratcheting wrenches. I've been reading every thread I can find on them, the most universally loved ones are the XL Kabo-made double-ended flex non-reversible. The main concerns people express are that you can get stuck on a fastener, and then can't back it up. Some have said you could disassemble the wrench end if it gets stuck. And most say it's a mistake you will only make once.
I dont want to make the mistake once, but I can't visualize how it gets stuck, and couldn't find any videos on it. Can someone please explain how and why the wrench gets stuck, how to avoid it, and how likely is it to happen once you know about it?
I don't understand why you wouldn't be able to just remove the wrench straight off. Can't you always back the wrench up, because it's ratcheting, so you can't tighten it any more, but you can always back the wrench up even though the fastener won't move backwards, can't you?
I suppose you might not be able to get to the bolt with your fingers.
