How do you guys store all your 'toothpaste' chemicals?
GuerrillaBuilds
I've been poking around on the forum and google looking for smart ways to store all the RTV, locktite, superglue, etc. toothpaste tube style chemicals that also helps guard against leakage. Currently they're all loose in a toolbox drawer and that just causes me to lose sleep at night.
SO, any/all suggestions appreciated! Thanks!
Bogie1632
Southeastern Wisconsin
No pic currently, but mine are in a board I drilled out with some holes and mounted to the wall. All go in upside down and the ones I use are readily available. I don't cap the tubes, I just let them dry in the nozzles and clear them when I use them next. Never had a tube dry up on me yet. ... Yeah, me! My few epoxy are hung the same but instead of holes in the board it has a long slot cut out.
V/R
Bogie
ducksface
Try this.
lolaetype
North Western Arkansas
Mine reside in a shallow drawer of my workbench.
Am I the only one who has a problem with the caps for some of the tube splitting and letting the contents set in the tube. It happens to me with every tube of Permatex Black Gasket Maker I've bought. I've never used more than half the tube before it goes bad.
liliysdad
Yes, but the culprit in my life is weatherstrip cement. I have to buy a new tube every time I want to use it. The other issue is with E6000, which is an adhesive that I have come to absolutely love. Often times, I find the glue has set in the lid just enough that the lid is glued to the tube.
tre873
NE TX
I believe the package says to smear a small amount of petroleum jelly around the threads before putting the cap back on. It's supposed to prevent the cap from sticking.
nadogail
Coronado, CA
IMHO, Supposed to and does are not always the same.
I use a cutoff plastic quart motor oil container.
G
GuerrillaBuilds
Haha, I saw the lilredex solution in my earlier search. I like the binder clips idea and zip lock bags are a duh moment. I went to dollar general and they have these great little trays. might go that route with ziplock bags if i can spare the drawer space. If not, the binder clips are great. might put some sorta catch tray below them if any start to drip.
Thanks guys, this is more than enough to get me off my ***!
NUTTSGT
Northern Central Ohio
My Cman toolbox has the smaller drawers on the right side. One drawer has a couple little plastic baskets in it, about 4"x 4" square. One basket has tubes/bottles. Another has spare caps, you know the ones that don't split (luckily) so I save them.
There's a third basket that I can't remember what the hell is in it, but I know when I need it, where it's at.
If I remember, I'll snap a picture tomorrow.
Ries
North metro in MN
I keep them in ziplock bags in a plastic tote in a cabinet with all my other chemicals. I feel like it’s helped make them last longer too.
niget2002
Josephine, TX
Whatever shelf my wife and kids last left them on. Hopefully within a few feet of the shelf they're supposed to be on.
Sent from my LM-G820 using Tapatalk
ducksface
I just checked almost thirty lids, some of them 30 years old.
No cracks.
I've never seen a cracked one.
Jlarson
Small akro bins in the shop, one for loctites, one for RTV's, one for glues... in the service truck one big bin.
dogdog
Same here. The nasty ones in zip log bags, separate them by types... means for epoxy, I separate the hardener from the epoxy...
ezover
3rd rock from the sun
:pSitting on a cabinet shelf, I have 2 draws on slide outs that I have been wanting to mount under my work bench to store them in. Draws have been sitting on the shelf for ten years or so, maybe next week I’ll mount them......:p :p
BonzoHansen
I keep them in one of these bins.
These bins are great for the garage. I use some to store stuff on a shelf under my bench. I use the larger ones for projects to throw tools, parts or supplies in. Way useful. And you can usually grab them cheap used. Throw the rack away
MarlynOC
Warrington PA
Plastic shoe box for most tubes. Superglue once opened goes in butter opening in the frig to keep it ready to use.
Bogie1632
Heres a quick pic of my rack. Never had a drip issue and I usually only use a few types so space isn't an issue either.
V/R
Bogie
