bjaspud
Does anyone have any photos of a good way to store scraps of wood? I'm talking miscellaneous partial pieces of 4 x 8 sheets. Random lengths of 2 x 4 or 2 x 2's etc.
Thanks,
Spud
Thanks,
Spud
store it on the brush pile, with a lighted match underneath
So THAT's what you use the 'possum van' for!.I have a van in the backyard with anything over about 2 foot long piled in it. Anything shorter get placed in the crate of kindling near the wood burner for the winter.
Here's one idea.
I had a link to a plan somewhere (can't find it now) for a cantivered rack design. I was going to mod it a bit to storge sheet good as well as lengths plus put it on casters to move it around as requied.
I have a basic physics question for you guys regarding these cantaliered wall mounted racks. When you hang a shelf/rack system like the triton on a stud wall how much force is being placed on the wall in the horz/rotational/lateral direction? Or is all of the weight/force 100% vert down the studs? In other words are there other non-vert forces which might distort the wall in other ways? My concern is that the weight of the rack and these non-vert forces can with time, bow the vert plane of the wall? Anyone know how to calc the lateral forces?
Thanks for the post, I have always wanted to use that dead space in the garage but wouldn't have thought to screw into the railing for the other support. I want to try storing the ladder but I can't see how you did that, can you explain it a little more or send a different angle in a picture? And how did you do the pool on the ceiling, I want to store 3 long tables that we only use every once in a blue moon but can't get rid of, so I wonder if your idea would work for that but everyone thinks I am crazy for trying to do it on the ceiling, so can you explain that idea or send a picture also. Thanks so much.I have a 3 car garage with two doors. The Entry door is on the front corner of one side wall. I took a 2X2 and screwed it to the garage door rail. Then I did the same to the wall of the garage at the same height. I did the same between the two garage door rails in the middle of the garage, as well as the 2nd door and the other wall.
Then I used scrap T-111 siding and plywood from the forms to lay a floor across these 2X2's.
Now I've got three shelves.
One, over the access door is where I store my scrap long lumber like 2X4's of varied lengths.
I am planning on a 4X8 lowerable hinged platform above one side of the double door that will hold 4X8 sheets of plywood and large flat scrap. I just finished mounting a lowerable carriage for storing a kid's wading pool against the ceiling over the other side for the door that works slickern' snot.
The middle shelf between the two garage doors stores lengths of pipe and spare/scrap gutters. Under this shelf I store my 8' extension ladder, it's easily accessed and tucked up out of the way when not in use.
On the other shelf I simply store boxes.
Everything's tucked up out of the way nice and neatly.
Dog Nabbit, Caper, you beat me to the punch!
