I can't really tell from the pict , how close to the surface it is broken off , but a little trick I have done several times is , select a nut same size as the broken bolt , set it on the head , centered exactly over the bolt , take a 1/16 welding rod with the proper amp setting , put the rod straight into the broken bolt and weld it to the nut { disconnect battery lead first , to protect the alternator and computer if it has one } if it breaks off the first attempt , try it again , allow it to cool for a few seconds , gently put a socket on the nut and rock it slightly , { loose to tight } it it is very free , just back it out , this requires a good steady welding hand , trust me it does work well , Frank
