XterraJohn
I did it in the driveway and used a grease gun to build up the pressure. I tried to remove every bit of air that I could so as to hopefully not create an explosion if something were to fail.
Nope. There are no compressed gases of any kind used in hydro testing AND the vessel being testd is secured inside another water filled tank. You also were 100 Psig over the MAWP and test pressures of that vessel. Air is compressible, water is not. Leak testing with air at 30-50 Psig is just as effective as testing with water at 150 Psig.
Tommy
Thanks for filling me (us) in on hydro testing. But one more question...since water is not compressible, how do you put it under 300 or 200 or 100 or even 50 psi? Does the operator rely on the elasticity of the steel tank?
I have a thread about removing/inspecting the pump valves. You might want to take a look at it:
http://www.garagejournal.com/forum/showthread.php?t=324960
So how do you get 1.25 tubes of grease out of your tank?
This!I'd have left the grease in the tank. It's not like it's going to cause any damage, especially if you aren't painting with the compressed air. Eventually, I'd expect the grease would blow out the bottom as you drained water. Who cares if there's grease inside the tank?
It runs!
Unfortunately, there's still a wobble on the flywheel in spite of it being new, so I'm guessing the crankshaft has a bend in it. I don't imagine it's enough to be a real problem, but it's just enough to irritate me.
I uploaded a video of it running.
Did you dial indicate the shaft?
