how many lights
shadowrider509
just built a 32x40 garage with 10 ft walls, going to put the 8 ft. 4 bulb fixtures from lowes up , but not sure how many i need. shop will be used mainly for woodworking.
Steevo
43.49600, -112.04300
I used 17 of them in my 24x40 with 12' ceilings:
Modifieddriver
Moonville, South Carolina
I'm slightly confused on the number.
Let's try this: What is the total # of bulbs used to make that shop look brighter than daylight???
When we talk about # of fixtures, it gets confusing because we have 2,4,6, & 8 bulb fixtures.
Again, are you using T8's or T5's?
I'm about ready to buy about 20 4 & 6 bulb HB WB T5HO fixtures, so what you've done is a gauge for me. Are you too bright or just right?
sed6
I can see 29 fixtures there. Each with two 8 foot bulbs. T8's with electronic ballasts for cold starting and no hum are the way to go.
Steevo
Mine are 8-foot fixtures, each has four 4' T8 tubes.
The three center rows are 4 fixtures each, then two in the far row, with a gap between them where the bathroom is, and above where the picture was shot from there are three, in an L-shape, around the corner, above my workbench.
68 tubes total.
Lighting is just right for working.
dimarcelli
I count 16. 2-4-4-4-2 from left to right.
edit: yup 17 was hiding i had a feeling.
NHBandit
East Tennessee
68 tubes total.
No wonder you had to photoshop those Ray Charles glasses onto your pic...
Modifieddriver
68 tubes total.
Using your info for the lights a size of the shop, and doing a SWAG, you are at about 130 Foot Candles.
That's more than my charts shows for a body shop, which is 80-120 FC.
You can do some fine work in there. COOOOOL :):)
40cpe
Star, MS
For reference, this is twelve 8 ft-4 bulb fixtures in a 30' x 40' mounted 12' and 14' above the floor. This is 120 lumens sq/ft compared to Steevo's 198 lumens sq/ft.
Modifieddriver
Are those T8 or T5 bulbs ? You have 48 bulbs for 1,200 sq.ft.
I'm looking at 84 54watt T5 bulbs for 2,400 sq.ft. That's 130FC. I don't know how that translates to Lumens? Each lamp puts out 4,450 Lumens.
So, would this be 156 Lumens?
My other shop is 34'x48'x10'. That's 1632 sq.ft. Looking at installing 64 54w T5 bulbs. That computes to 145FC. Each lamp is 4,500 Lumens.
So, would this be 176 Lumens? If so, I guess I could back off on the number of bulbs.
Not sure how to calculate Lumens :dunno:.
40cpe
Star, MS
my lights are T8, total of forty eight 32 watt bulbs rated at 3000 lumens each.
Calculate lumens by (number of bulbs x lumens per bulb divided by sq ft.)
Steevo
Don't back off.
176 is good working light.
