How not to provide panel access
pmiranda
Austin, TX
Saw this the other day and thought you’d get a kick out of it. If you ever needed to change or add a breaker here, you’d have to remove the whole cabinet! On the plus side all the circuits are nicely labeled.
NUTTSGT
Northern Central Ohio
Yeah, Ikea cabinet installed by somebody who didn't know there were rules. Same folks also mounted a different cabinet in front of a wall outlet and snaked an extension cord out from underneath!
That is just typical America.
Mobile homes with breaker boxes in closets with **** pile in them . . . without the covers on them.
P
pmiranda
Austin, TX
Note that the sparky was not responsible for cabinet placement. I actually don't have much quarrel with the breakers... are you annoyed at the empty spaces?
PoorUB
Fargo, ND
I will admit I have a cabinet mounted over my panel, but It is much larger than the panel and no back or top on it other than a face frame. It is shallow too, maybe an inch deeper than the panel. Plenty of room on the sides and top for service or adding circuits. I just added a 6/3, 50 amp circuit with no issues.
Yeah, I know, it probably violates NEC, but I don't care.
P
pmiranda
Austin, TX
I suppose that's one nice thing about these classic large format breakers... more space for heat dissipation. My house has those tiny slim breakers packing dozens of 15A lighting circuits in a few inches.
mike93lx
Richmond, VA
And with each of those lighting circuits pulling less than an amp or two, it doesn't matter. Didn't even matter when everything was incandescent, either.
Norcal
Trailers "mobile homes" are not built under building codes, they are built to HUD standards.
u2slow
BC
I take zero responsible for the sins of interior finishers and other handymen.
Mobile homes aren't exempt from rules, they have their own rules - and then regular Code takes over for modifications. I'm not aware of any exceptions for panel working clearance.
johnre
Portland, OR
If sparky had to get in there he/she would not remove the cabinet. Out comes the oscillating tool and voila, a new bigger hole.
I think the cabinet back opening was cut to a large enough size that the panel could be removed.
Then they covered it with the black tape to trim it out all nice and neat.
But they could have used a sharp knife to finish it like a wallpaper joint; it might not even be noticed - not. :)
larry_g
oregon
I just make the assumption that the cabinet is on wheels... Just as so many assume it is not.
lg
no neat sig line
sparky 1971
Central Iowa
Is it me or the picture? How in the blue hell is the panel cover held on? It looks to me like the sides of the cover have been cut off and there aren't any screws.
By the way, I've seen worse. I went on a service call to add a circuit and receptacle where a wall with no access behind it was built about 4' away from the panel, the only access was a hole 18" wide and 2' tall in the wall in front of the panel with a kitchen cabinet door screwed to it and arms weren't long enough to even open the cover door without standing on a paint can so I gave the customer three options: 1) I could cut a hole in the wall big enough for me to walk through, 2) he could cut a hole in the wall big enough for me to walk through, or 3) I could leave and he could find someone else. After being informed that I was an ungrateful lazy ***** that didn't feel like dealing with a little obstruction, I told him he was an effing idiot and left. When I got back to the shop that afternoon the boss informed me while laughing that he had a call from the customer complaining about my attitude. When I told him about it, the boss called the customer to tell him that he talked to me about it and that he was, and I quote, a *******. If I could find someone like him to work for again, I'd shut my business down in a heartbeat.
mike93lx
Richmond, VA
The cabinet is covering the screws
johnre
Portland, OR
I think we are all being way too harsh on the black tape thing. Tell me who amongst us isn't aware of its ability to cover up and thereby ignore a MIL on an old vehicle? :)
SlotlessMan
NW WI
I am no electrician but I do not see a glaring issue with the box itself. Likely, the surround was done by the homeowner or his brother well after the electricians truck and inspector left the driveway. Not a wide enough picture to discern more.
97tj-neil
PA
You are taping your Mother In Law to your vehicle?
Firebrick43
West central Indiana
The farm house I spent my the majority of my youth in had the fuse panel in the shower.
That was the first of many things my dad changed when he bought it.
dcg9381
Austin, TX
Probably about like RVs are built to RIVA standards:
"The team conducts more than 2,000 unannounced inspections of member company RV manufacturing plants annually"
As about 600,000 RVs are built in the USA every year, that means that less than 1% actually get inspected.
"Voluntary standards" (IE standards not associated with an actual inspection) are not standards. They're just stickers.
