How often do you use your shop press?
BD1
north side
'' Where did you get the little round handle for the valve release on the jack? That is pretty slick. I need to put something like that on mine....''
My handle and valve stem is from a junk Stockham gate valve. I left the valve handle on THE BRASS STEM and cut to length. I drilled the center of stem to slide over the jack screw release with the pin removed. Then drilled through the stem for the pin to go through the existing release screw. It's still holding up fine.
excavator
I use it when I am under pressure (LOL) to get job done.
I can't be with out my press, most valuable in any garage or shop even if only used few time a month
