How Powerful is this Grinder??
BJ42LX
WNY
8 amps at 115v = 920 watts
Google says 1 watt = 0.00134102209 hp
The solution is an exercise for the reader...
drivesitfar
Ex: check the block grinder thread because i think a block can be had for that kind of money in your area and they are one of the best grinders for the money i know of. also Tourqueman and a few others might have a restored one to sell you if you ask.
that isn't a bad grinder for $30, but i'm sure it would not be close to what you would like unless you just like the look of it.
BJ: thanks for the math lesson :)
zkling
That is one of the better grinders of that style I have seen, but unless you need a grinder yesterday I think I would look for a more traditional style grinder. The motor clearance and thus wheel accessibility on those is pretty poor.
Not quite, you are forgetting the efficiency factor which is about %60 at load if not lower. I guess the true solution for the reader lies in completing your incomplete offering. ;)
E
exmaxima1
Midwest
I already have a bunch of grinders, including a few blocks, but that one caught my eye mainly for being made in my town (Geneva) and the amp rating just seems way out of wack for a cheapo grinder like that. That's nearly twice the amperage of my Baldor 1/2 hp, and close to what my Dayton 10-inch (1 hp) draws.
E
exmaxima1
Midwest
BJ42LX
WNY
I did a little digging and found the same grinder sold under another name. Same 8 amp rating, but also listed as 1/4 hp-----talk about massive losses!!
zkling: Yeah, you're right. exmaxima1 is looking for rated output which is different from peak load.
Normal running I suspect it's only an amp or two which is consistent with 1/4 hp.
