Local code here does NOT allow a drain in the garage to be hooked up to the sewer. I can understand that. But they also do not allow a drain to be installed to the yard as run off either. If I put any drain holes thru the wall, it must be filled with concrete before it will pass final.
So my plan is to install a few drains and drain them to a sump pump basin. Then after the final, I'll punch a hole thru the wall and drop in a sump pump. This is only for washing cars and snow meltoff. A contained system the way I see it.
Any thoughts on this...
