SBC350
Hi,
Ive been looking at multiple post around GarageJournal and other sites thru google but I need help with my storage "loft".
Specs:
It is a bit under 23' wide and 48" deep.
All built using 2X6, and planning to install 5/8 or 3/4 plywood on top.
Just so you know, I will double the "front" 2X6. I used GRK Fasterners on the ledgers board.
Now I need some suggestions/tips to add some structural strength to it. I want to keep the floor free as I'm planning to a 4 posts lift down the road.
I was thinking of adding 2, 45degree bracket under the loft.
Or adding 2x4 or 2x6 in the truss, that will run perpendicular to the truss and attach a 2x6 from the front of the storage loft to the truss. But I know truss arent made for weight pulling from under.
As a side note, I am planning to put, regular household junk such as
decoration, sports gear, offseason tires, kids toys. No engine block or anything too heavy on its own.
Thank you
Alex
Specs:
decoration, sports gear, offseason tires, kids toys. No engine block or anything too heavy on its own.Thank you
Alex
