How to clean PVC pipe
Cope
Houston, TX
I am cutting some Sch. 40 3/4" PVC water pipe to make a quilt display stand. What can I use to remove the marking on the pipe without melting it?
tcianci
Walpole, Ma
Try Some very fine Scotchbrite, maybe the white stuff. Otherwise there are lots of spray paints made for plastic that work quite well.
katmat
Why not try a little bit of pvc pipe cleaner & then wipe it w/ something or try acetone.
7echo
coastal Georgia
Try denatured alcohol, maybe it won't melt the plastic.
But sanding, good primer, and a top coat will likely make a better finish over all.
C
Cope
Houston, TX
Thanks for the replies. The way I made the stand all the markings are either covered or not visible from the front.
FullRaceMerc
SoCal (SGV)
I just used some denatured alcohol to clean sharpie off of PVC this week. Worked great. Didn't seem to affect the sheen of the PVC.
G_P
Central CT
I accidentally got some engine degreaser on PVC pipe and it took the writing off and left the surface of the pipe undamaged.
