DMucci
I have a set of motorcycle handlebars I was planning on running wires through. I found out the bars had long nylon inserts/plugs embedded about 6" down into the bars.
Long story short there's a drill bit stuck in the nylon insert inside the handlebars. The end of the bit is about 3" inside the bar so I can't just grab it with the chuck and back it out.
Anyone have an idea how I could get this out? Is there a tool that exists that's basically a female screw extractor? (inner threaded pipe with a tapered reverse thread)
The drill bit shank is 1/4" and the handlebar ID is about 5/8". Here's a cross section:
And here's the contraption I made that got it stuck in the first place. Thread tap chuck welded to the end of a sold rod. The chuck's grip on the bit let go and I have no way to retighten it down inside the bar.
duh.
