How to fix stuck "button" on ratchet
M-EGT
PHX
By button I mean the ball that holds the socket in. Mine is stuck so the sockets don't really stay on. It's my SK Wayne 3/8 ratchet which I quite like to use!
Thanks
JUNK-MAN
PA
I don't know if you can fix that problem, I have tried in the past and failed I had a nice Mac universal extension that one day decided to do the same thing still haven't fixed that I think the spring is busted from running sockets on and off that's probably what is wrong with yours too. You may be able to get a rebuild kit for yours and fix it that way.
n8n
Curtis Bay, MD
Yeah if it's just the normal round head they still make them, just call SK and get a kit for it. Probably won't even get charged for it.
Sent from my XT897 using Tapatalk
Anarius
SE Michigan
Try soaking it in a small container of transfluid over night, then smacking it against something. If no success, rebuild time
M
M-EGT
PHX
Time for a rebuild
That sounds like the consensus. I'll do that.
Funnily enough, I did that not too long ago. It got stuck shortly after :lol_hitti
XxToolAholicxX
SF **** Bay Northern California
You can try lubricating it fixing it i don't think so as the ball is pressed in. Get a rebuild kit from S-K for it. Email them leave the model number your address and phone number you will get one in a few days at your front door at no charge. S-K has the best warranty in the industry. Besides Craftsman. Lol
I am a ToolAholic,Sometimes I regret it,Especially when the Toolman wont give me no credit
Noland
sometimes brakecleaner helps clean it out and work better if its got dirt and grime in it.
RM209
MD
Thanks
Sometimes the ball isn't stuck, but actually broken on the backside; the result is the spring can't put enough pressure against the ball. I discovered that several months ago when I had a 1/2" drive extension that was stuck; when pressing the ball and moving it, it was clear that half of it was missing.
RM209
M
M-EGT
PHX
Just an update, I emailed SK with the problem and a few hours later they responded saying a repair kit was on the way!
M
M-EGT
PHX
Just an update, I received the kit and fixed it! Its now super quiet (so much so that I wasnt even sure it was working!)
