How to hardwire an under cabinet light?
NETexas
Attached
I would like to hard wire a light on an outside wall with blown fiberglass insulation. I want to add a double gang box where there is a single, and add a switch and power it from the outlet next to it. The part that I’m hung up on is where to drill the hole to pull the wire to the light. Should I drill hole in the Sheetrock and run the wire under the cabinet to the light which will be visible, or drill hole in the back of the cabinet and run wire inside cabinet to center of the back of cabinet and drill another hole to the f93b3f360132bc194b173e2c6bf35e59.jpg2259f85661f46732c1d2e4a590f09eb5.jpglight?
I live in the country and no inspiration or permits needed. Hope photos help explain what I’m talking about.
MattN03
KY
I mounted my undercabinet lighting about as forward under the cabinet as possible. I then drilled a hole just large enough to pass 14/2 through the bottom edge of the cabinet and pulled it through, allowing the light to be hardwired. You can see this in the picture. (Nevermind the drywall being cut out as this rookie stubbed out his electrical to low under the upper cabinet and had to repair drywall too...)
I thought about going through the back of the cabinet, but I didn't want a wire getting in the way of putting stuff in the cabinet. Probably not a problem either way, just personal preference.
rok_hunter
home
We had ours installed inside the cabinet with all the plugs wired to a switch. Then we used a smart plug and some LED light strips for the under cabinet lighting.
e11aac0cda28f7ab8e1ecbead62a20c1.jpga0a56acc0c5a07b74f6da7d9e5dd8356.jpg1f17abfe4e8e758751e2c8bf410a89ce.jpg
N
NETexas
Attached
Thanks for the suggestions. Plan to go into the back of the cabinet.
The light I’m using from HD $20 has a knockout in the bottom for hard wiring. Just unplug the wire in photo.
CitadelBlue
Northern VA
Easy. You dont need to add another box unless you need the outlet. Here is what I did.
N
NETexas
Attached
Found that local Ace Hardware store has them in stock.[emoji1417]
Sent from my iPad using Garage Journal
