BikeRider
I'm about to try to rebuild an automatic transmission, but to remove it from this car (A140E trans, 3rd gen Camry), I have to support the engine from above. There's no safe way to do it from below from what I can tell, as the subframe has to be removed to remove the trans (its overdrive unit won't clear the subframe).
I ended up ordering a used engine support bar from Amazon in supposedly "good" condition, of this type:
I just got it today and it's missing some important parts, namely one of the two holding screws, and the chains. So it's going back.
But given that Amazon and/or the vendor tried to screw me over with an incomplete set of parts without saying so, I feel that I'm justified in trying to use it anyway, as a "free loaner". It's a one-off job and I'll probably never need it again (so he says), which is why I got it used. I just have to figure out how to securely suspend the engine, which has 2 hooks on either side, from the beam, which is solid and intact.
Any ideas? The obvious way would be with 2 strong chains and some way of securing them to themselves, but I don't have any chains. Is there anything else that would work, some kind of strong S hook or many loops of strong wire or even cord, tied well? I think the engine weighs around 430lbs. I might even be able to use the one screw and only need a way to secure the other hook.
I have some old bicycle chains that I'll never use again, and wonder if they're be strong enough, especially if I double or triple-wrap them. Apparently they can withstand at least 800lbs of force, which is plenty for this task.
...I just checked and a bike chain fits perfectly, allowing two full wraps, one on either side of the beam. Even more if I removed the 2 "feet", which in any case seem wobbly to me and unstable and secured by just a few turns of the way too short bolts attached to the upper knobs. In fact I might remove those too and use just the beam itself, resting on a solid piece of metal on either side as it overshoots the engine bay by a few inches on either side.
