So I had another thread where my mini-split was leaking and I patched it up.
So now I am looking at the unit and wondering how to check for leaks using the gauge on the low pressure port. There isn't a high pressure port, so I can't use a gauge on that one.
Everything seems to be running just fine two days later, but I would like a more analytical checking program.
As far as pressures go, with the compressor off, the pressures on the low side are around 225.
With the compressor running it varies between 80 and 110 depending on how fast the compressor is spinning.
If I had a refrigerant leak, would the pressure be dropping below 220 when the system is off?
So far so good, but I am trying to keep up and log the system to see if I still have a slow leak or not.
