Need to do a Honda V6 timing belt soon. The crank pulley bolt tightening calls for a two step process. First torque it to 47 ft lbs. Then turn it another 60 degrees. I am having a whole bunch of questions for the 2nd step. Hopefully someone more enlightened can pass on valuable lessons. Thanks in advance!
1 Why turn it another 60 degrees? Why not just torque to a number like 180 ft lbs?
2 What is the correct tool to turn it 60 degrees?
3 Foreseeing that the correct tool is not going to be cheap and probably will be rarely used and need subsequent calibration, is there a home-garage way to turn it 60 degrees semi accurately?
4 Can I simply torque to 200 ft lbs? As long as the bolt survive the initial test, engine by itself will keep tightening it, right? It takes way more than 200 ft lbs to remove it. So why not tightening it to a high number like 240 ft lbs and call it a day? (My torque meter goes up to 250 ft lbs.)
5 I have a DeWalt heavy duty 1/2 inch battery impact wrench. The max torque @ level 2 according to the following website is 400 ft lbs
https://powertoolspros.net/dewalt-dcf899m2-review/
Can I simply bang it at the 2nd setting and call it a day? This way, I don't even need to buy a crank pulley bolt holder.
