thejudges69
Judge: I have been working on truck for 30 years it shouldn't be a problem. That said I have looked through your build threads and I understand the level of quality you are looking for, the rest of your equipment is top notch from what I have seen and I get it. the idea of a making your own split bushing out of UHMW plastic seems to be the best to me. The plastic makes a good bearing surface, while not needing lubrication. In addition it will dampen the metal to metal contact. I would get a piece 3/4" to 1" and cut the correct size hole with a hole saw then slice the "doughnut" in half and bolt the two halves over the pipe. With a couple of bolts securing the "doughnut" to the frame.
Post up a couple of pictures of your solution please.
I will post what I come up with. Most may say there is no issue, I personally don't like it. The rattle when I'm hitting bumps drives me nuts. A pillow bearing is an expensive option that I won't roll out.
Your suggestion I'm not quite following, what would I bolt it to the frame with? Some type of housing?
