How would you re-attach this Craftsman toolbox badge?
1982fxr
Phoenix
pics...the 'tabs' broke off
2nd picture is outside of the box
last picture is inside where the tabs broke from the emblem
k p
Ontario, Canada
I'd probably put it back in the same spot, but remove the peg remnants on the badge and use superglue around the back edge perimeter.
OR See if you can just find a replacement badge, they might be cheap?
zkling
Me? I would epoxy small, strong magnets to the back of the badge. Then place it where ever you see fit on the box. I guess you could use double sided tape, then trim around the outside of the badge, but the magnets sound much easier. Just my 2¢ :dunno:
rsanter
visalia ca
Adhesive. Like the stuff body shops use to hold the emblems on the newer cars.
You can also use adhesive silicone or double sided tape ( the foam backed type)
Bob
James-W
Southeastern Wisconsin
If you can remove those “tabs” and if you can get to the back side of where the emblem attaches, I would use a Dremel tool with a sanding disk to remove the material on the emblem where the tabs were. Then I would use epoxy to mount two small bolts on the emblem so they line up with the holes in the tool box. Use two washers and two nuts and the emblem should be mounted pretty solid to the tool box.
Canoe50
Rochester, NY
GE Silicone 2. I use it all the time as a bonding agent & it works great. Guarantee it will well for your application.
jjjrmx5
Cincinnati, OH
Bob
This.
3M automotive adhesive trim tape.
Found in any Walmart.
Grey tape with red backer.
Adhesive both sides and is very thin.
I have serveral badges held on for more than a decade with the stuff.
It's sticky as f&^% but can be removed with dental floss and cleaned with mineral spirits, Naptha or 3M adhesive remover.
djjsr
In the cornfields
Another vote for 3M trim tape. Stick it on the badge, trim the edges with a razor blade, peel the backing and stick it in place.
Get it in the right spot the first time because that tape doesn't come back off easily.
I just got a bunch of new motorcycle emblems and they all had the tape already applied. Easy job, just peel and stick.
wayne55
I had a similar problem, but my tabs did not break. Just the ends of the plastic label were bowed out away from the chest. I drilled holes at both ends and put small screws in to hold it. I painted the screw heads black to match the background color.
1982fxr
Phoenix
Better yet, why not a snap on badge? It would increase the value of the box 2 fold at least. :lol_hitti
Joking. Please don't put a badge other than Craftsman on it.
naaahh, the only time I would ever consider putting a different badge on a toolbox would be if I was painting one up custom and put something cool like "Oldsmobile 442" badges or something. karma gets people who pull that re-badgeing "up" ****...:thumbup:
I ended up using super glue because that was what I had. Seems to have worked..
djjsr
In the cornfields
...... karma gets people who pull that re-badgeing "up" ****...:thumbup:
What do you mean? I remember when General Motors re-badged the Chevy Nova and made a Pontiac Ventura! Did bad karma get Pontiac? ............ Hmmmm ......... ok, that was a bad example.
Well, they rebadged the Nova and made an Oldsmobile Omega and Oldsmobile has .........uh ...... uh ..............ok, that wasn't good either.
Ok, ok, the Ford Taurus! Yeah, that's the one! Ford rebadged the Taurus and made a Mercury Sable. Good seller, right? And Mercury dealers all over have been doing just fine. ............... Mercury dealers .............. hmmmmm ........Mercury dealers ......... Come to think of it, where are all the Mercury dealers?
Ok, you may be right about the re-badging thing.
