trainer
I'm going to rewire a small cabin this spring. It's off the grid, powered by a 3000 watt 120v generator.
The generator is neutral bonded and has a 30amp rv type outlet on a 25 amp circuit breaker.
Generator will be installed in an enclosure approximately 75' away from the main camp with a buried cable.
Panel will be a 4 circuit pony panel using one 25a breaker as the main and feeding three 15a circuits.
first question..Grounding Should I have a ground rod at the generator, the point of entry to the cabin or both?
2. any issues with using two paralell runs of 14/2 direct burial wire instead of one run of #10? I already have the #14
3 any special things that need to be done because the generator has a bonded neutral rather than a floating one?
