93fs
Trying to troubleshoot my mig, I’ve had it for a year or so and used it on and off for mostly exhaust and body work application and so far I love it, it has a voltage/amperage readout, and I decided to see what it would put out on some heavier gauge metal, so I grabbed some 1/8” steel and cranked the voltage settings up and though it seems to be welding decent, the highest amperage I saw on .030 wire was 160 amps, after watching a couple others on YouTube with the same machine, similar settings, were around 200 amps. So today I decided to throw some .035 in it, same result, wide open on the settings only got me to 172 amps.
So just for fun I looked over the wiring in the garage. I’m far from an electrician, but the main breaker in the garage is a 100amp, and the welder is on a 30amp breaker with 10-2 wire run to the plug. I’d think if the garage wiring was the problem it’d just pop the breaker, but is that not the case? Is it possible I’m not “flowing” enough current to get the full potential from the machine? I plan on calling HTP at some point to pick their brain as well, but I figured someone on here may have the answer. I have no problem putting a bigger breaker and wire in, but I don’t want to waste the money if it’s not needed. It looks like the plug on the welder itself is labeled 10-2 as well for what it’s worth, also the receptacle is roughly 40ft from the breaker box.
