Hurricane damage to electrical systems
b-boy
Buffalo NY
My Sister is in Ft Myers. Her house was flooded during hurricane Ian. The water reached the 4ft level inside the house.
She's a long way from being able to get anyone into the house to do any work. My Dad is down there helping her clear out the house. I'm probably going to go down and help take out the drywall and open up the walls so they'll dry out.
Since the water reached 4 ft inside the house, all the electrical outlets were submerged in salt water for about 24 hours. I assume all the outlets will need to be replaced.
What about the wiring?
b-boy
Buffalo NY
My Dad is currently at the house. He noticed that the water level inside the house is quite a bit higher than it is outside.
I can't figure out how that would happen. Maybe water came up through the sinks/toilets under pressure? is that possible.
One of her neighbors actually broke her sliding glass door so that the water would drain out of the house.
yes very possible... could be nasty sewage in the house.... good reason to install an anti-backflow valve on the sewer line
Norcal
If the water reached the electric panel, trash it also, as been said already any NM cable that was submerged in salt water is not salvageable except as scrap metal.
sparky 1971
Central Iowa
No effin' way I'd use the in wall splices. I'd trust buried wire nuts before even considering those things.
And, before anyone jumps me about code, I know wire nut splices have to be in an accessible box. Just sayin, the in wall splice kits look like a good way for a service man to make a ton of money as well as a drywall patcher somewhere down the road.
Norcal
I share your reluctance for those.
Jim greengo
Behind my house
I'd say any wiring that was exposed to salt water should be replaced.
jeepxj
what about factory splices in romex?
jeepxj
Factory splices? What are these shenanigans that you speak of?
These in wall splices look like t-taps to me...no thanks, I'll put in two junction boxes if there isn't length available to make up the loss
sparky 1971
Central Iowa
are those no go for you as well?
I've yet to knowingly run across one. If I knew a factory splice was there I would definitely try to not use the spliced part of the wire. However, I have probably installed hundreds of factory splices and didn't know it.
Factory splices in romex and those crappy in wall splice repair kits are two different things so I'm having a hard time seeing your point.
jeepxj
you were hinting at not liking any splices. i'm being a bit cheeky as a welded factory splice is probably less resistance than the wire itself.
i do agree i wouldn't trust those certified in wall splices for anything more than a detached garage.
sparky 1971
Central Iowa
The only thing I hinted at was that I won't use one of those repair kits. I splice wires all of the time...with wire nuts. The things in question aren't really any different than the mobile home devices where the device and box are one piece.
And if the factory wire splices you posted are welded, I have no problem with them. I have honestly never seen, heard, or even thought of one. It does make sense, even the manufacturers have to run short on wire once in a while.
jeepxj
i just assumed the factory welded them up to keep the line going. but i digress.
sparky 1971
Central Iowa
I'm sure you're right. They have to keep the line going, and there's no sense in tossing a 237' roll of romex because the black wire came up 13' short. I don't even know how romex is made, nor do I care. I am assuming that there is are spools of black, white, are bare fed into a machine that installs the jacket and spits the finished product out the other end.
And, as far as the factory splices go, I have never seen one in THHN style wire, and I've had miles of that run through my fat hands and would have felt it. I am going to guess those pieces of wire are left for the romex where the splice is concealed.
jeepxj
i'm guessing the THHN you've run is stranded? wonder if thats why no factory splices vs the solid stuff in romex being more readily welded. also with single conductor line things are probably more straight forward.
brb requesting tour of southwire.
yeldogt
You do need to replace anything that got wet ---- also taking out the drywall to a point above the water line is important and should be done ASAP.
Flowing water will fill a cavity higher than the surrounding areas -- the pressure pushing it in is greater than what is allowing it to flow out.
Did she have a flood policy ?
weadjust
Tupelo, MS
Too early to tell. She's not even sure what's covered yet. There's some question as to whether or not she's even covered for the damage.
Either she bought flood insurance or she didn't. Flood insurance will cover surface/surge water damage from the high water line down and homeowners insurance will cover wind damage with resulting water damage from the high water line up.
One problem that usually comes up. The kitchen base cabinets are damaged and covered by the flood insurance but the upper cabinets may not be damaged. The flood insurance will not pay to replace the undamaged upper cabinets.
dcg9381
Austin, TX
Per news yesterday 18% of people "inland" have flood insurance in FL.
About 50% have flood insurance if they are on the coast.
6 insurers in FL have already gone "defunct" in 2021-2022 - the blame was exceptionally high contractor fraud in FL and associated litigation costs. I work in an industry parallel to insurance, can tell you that FL has massive amounts of scam/fraud in that space.
b-boy
Buffalo NY
Here's a cool story - My Dad was working on the house Tuesday. Some buses pulled up from Florida Gulf Coast University. A bunch of college students climbed out and proceeded to go house to house and help everyone empty their houses of storm debris.
It took them about 1 hour to clean out my sister's house. It would have take her a week. They refused to take any money, and said they'd be back to help out in a few more days.
wow thats awesome!!!
