husky bar stools at home depot
chipper
Williamsburg, va
Not sure if this has been mentioned or even if its hot deal but hd has their husky garage barstools for $18 looks like online and instore sorry i couldnt copy the sku for some reason maybe someone else could
Delfonik
Warner Robins, GA
Vegaman_Dan
Pacific, WA
Note that these are only 20" tall, so that makes it more of a stump than a stool. :)
If these were 30" or taller, then I'd have a use for them.
Fizbin
Any of you guys think it's possible to install some casters on this thing?
I bought 2 of them today and assembled one of them a few hours ago. They're around 28" tall and pretty sturdy. The tubing doesn't seem flimsy at all ( but I haven't measured the thickness), so I don't see why you couldn't throw some casters on if you wanted to.
The only downside is the seat padding is very thin and I plan on adding more to the one for my workbench. At $18 a pop, it's a solid deal.
mrvm
PA
Adding a couple Husky stools to the garage. Much better value than the Gladiator stool
Hencini
One for the basement workshop, one for the garage workshop. Done and done.
Based on reviews, it sounds like the padding is pretty poor. Anybody have one yet to verify?
stage20
pcola FL
i sit on a little 2ft folding wood ladder. my mom got it at a yard sale a couple years ago. i also use it as ladder from time to time. might have to jump on one of these. im headed to hd now anyway.
panknuckshovel
Land o Lakes FL
What? Have you not seen reruns of Macgyver and the A-Team? Anything is possible. This is a good price on stools because one thing I have noticed is when it comes to the garage or the house somebody decided that stools are going to be the most expensive GD piece of furniture available.
C
chipper
Williamsburg, va
That seems to be the con of all stools i just put mine together and its not the best but its definitely not the worst
NUISANCE
Bay Area, CA
I grabbed one a little while ago when I was at HD getting a few other things. The padding is thin but bearable. It might be about 1/2 thick but it will work for my needs.
wrnchtwstr
OKC,OK
Just about the right height for working at the work bench. Or just setting around having a beer or two. Think I'll pick up a couple for the shop.
Hencini
Thanks for the feedback. Picking mine up today. :thumbsup2:
Ryan_C
IN
I order 2 for pickup yesterday. Already have them assembled. Quick and easy, seat could use a little more cushion but solid for the price.
tmshort
Central IN
Got 2 yesterday. Agree with the above ... a little thin on the padding but not bad.
I had to hit 2 stores; should have called first. Online inventory and in store inventory showed 4 at the first store, but no one could find any!
NUISANCE
Bay Area, CA
This weekend I put this stool on casters. I went to Ace and picked up some plastic caster inserts for the legs, 3/4 in size. Also picked up 4 casters rated at 75lbs each. Went home, popped off the leg caps, put in the inserts then put the casters inside of them. I like it WAY better now but I still catch myself picking it up to move it as I am not used to it having wheels yet.
The caster inserts I used are pictured below. After that just pick your casters and you are done.
