Don't know if this will help you or not, but I have an older (2005) Husky 7 drawer cabinet that looks like the older brother to the one you posted a link to. Made in Canada- don't know if that has changed or not, and mine is the PRO version.
If they are comparable, then it is a nice match to the top chest (I have that as well). I have only two complaints with the box that I have. First, the drawer stops at the back of each drawer are made of plastic and have a tendency to break after a while. I couldn't figure out what the weird-shaped pink plastic things were that kept falling out of it every so often. Does not impact function though, still closes and locks just fine.
Second, they are a little thin when it comes to construction. I assume you know what you are getting into as it lists the drawer capacity as 50lb. Don't know if it is different for my pro model, but there is significant lateral flex in the drawers if you remove them when loaded. They are solid when on the rails, but can flex enough on removal to the point where it takes significant effort to line the drawer back onto the rails for reinstallation. Only a factor if you remove the drawers of course, which I have to in order to move frequently.
I have been looking to upgrade as I have outgrown my setup, and admit that I have checked out the Harbor Freight 44, and from my observation, the HF uses much thicker stock than my Husky.
I saw a larger version for sale a few months ago when another GJ'ler posted about it, I didn't post favorably about it due to the flimsiness...at least for my needs. All around, the Husky is adequate but has its limitations. As long as you know what they are and it meets your requirements (and price point is nice which is what sold me when I bought it), then proceed!
