joe_pinehill1
My 1997 Husqvarna 41 is leaking oil. I replaced the oil delivery tube and the pump twice thinking that was the leak, and its still leaking. I took the bar off today, and the delivery tube look dry, and the bottom of the saw is soaked with oil.
I know this is a 20 year old chain saw but its only seen home use, still has good compression, and other than carburetor kits its has been running great.
Anyone know if these saws had a gasket or O ring in sealing the oil reservoir that may have failed or is the failure probably a crack or separation of the plastic tank casting? It is a mess when I store it, and have to store the saw on a pan.
I keep thinking of tossing it and switching to a $200 Echo.
Or has anyone tried one of the Milwaukee M18 chain saws?
well yeah, it could be a streak of luck.
