Hvac doesnt run as much on an overcast day?
Hobby_Man22
tx
It's still 95 outside even though it's cloudy, minus the sun beating down. This has me thinking I need more insulation on the roof. Currently have r30 would like to add another layer of r15 over the r30. I don't like how the ac runs constantly from 1-5pm. Sometimes it shuts off, but then kicks back on after 5 minutes
BrandonV
Arizona
Where in Texas are you located and what is the thermostat set at? As the outdoor temperature reaches the design temperature of your system the unit is going to get closer to running continuously.
chinboys
Borrow an infrared camera to highlight the area where the heat is being driven in via inadequate insulation or drafts.
Get a Manual J design calculation to verify your cooling tonnage.
Make sure your hvac system is working correctly... Refrigerant level and clean evaporator and condenser coils.
Correct the problems.
Realize with inadequate insulation, the heat transfer mechanism via radiation and conduction during the heat of the day means your air con system cannot keep up with the heat gain.
Set up a setback of 3 degrees on your thermostat. The system will run longer but also stay off longer.
Don't expect any system to have more than a 20 degree delta between outside and inside temperatures.
H
Hobby_Man22
tx
It will hold 72 when it's 100 outside, but it's going to run the whole time. If you kick it up to like 77 it will shut off for a bit. Like 10 minutes off before it kicks back on for another 30 minutes or so.
Sumboodie
AK
Not sure how you have insulation on aroof. Around here we usually do at least r48 in the ceiling.
No 95* though. Hit 62* today with sun (haven't seen that in weeks it seems) and I was sweaty.
mike93lx
Richmond, VA
Constantly running, but keeping the setpoint in the hottest day means it is sized perfectly. It's exactly what you want
liliysdad
I’ve heard this my entire adult life…and it’s absolute nonsense. It was 112 here today. If my system couldn’t keep my house any cooler than 92, I would be pissed.
System runs damn near all day, but maintains a temp of 73-74 on the hottest days. I keep the thermostat on 70 during the hottest part of the day, 68 at night. I’d have a mini split in every room if I couldn’t do better than that.
CraigStu
Blacksburg, Va
I am not sure I understand your thinking of insulating the roof. Are you conditioning the attic as well as the living spaces? Not that it would hurt to add more roof insulation but I wonder if adding more insulation to the attic floor, and working to get more airflow through the attic might be easier.
DGersic
DeKalb, IL
Sun heats everything more. Look at your roof, what colour is it? If it’s dark, it heats up a lot. Look at your windows, too. They can let in a lot of heat along with the light. Walls, similar to roof, light colours heat up less than dark.
Insulation slows down the movement of heat.
dcg9381
Austin, TX
In Texas, the roof insulation is a big deal. I assume you have an attic and insulation on the attic floor.
I assume your air handler is in the attic.
Adding spray foam to the roof deck will result in a substantial decrease in temperature in the attic, and then you have an air handler sitting in a space that is much cooler.
Adding more "attic floor" insulation isn't a bad idea, but it's not as effective as doing the roof deck due to the location where our air handlers are in Texas typically.
H
Hobby_Man22
tx
You can't add insulation to the roof deck down here. Everyone who does that gets mold. Has to be in the rafters
dcg9381
Austin, TX
Two of my three units are as well and it's hot as **** up there.
At least it's better than having a water heater over living space
Oh, I've seen houses with both "features".
I think they started adding radiant barriers to roofs in early 2000s, which helped with attic temps, but the temperature in a Texas attic on a "traditionally insulated" home and a foam insulated home is easily 20 degrees or more. That's a lot of added "efficiency" for an air handler and duct-work that might be R-4 insulated at best.
Are we talking foam insulation? Maybe we're not talking about the same thing? It's better to cover the rafters in foam to prevent thermal bridging from the roof deck, but yea, modern homes in Texas the attic is sprayed to the roof deck.
Here's my living room (no attic) - sprayed directly to the roof deck. In the attic, rafters are covered. There are "perhaps" issues with foam insulation and moisture in northern climates, so you'll likely see humidity control systems up north. But here, we run our HVAC so much that it doesn't seem to be an issue.
This is my 3rd structure built like this. No mold or issues other than an energy bill that's below average. Steel shop has the same insulation.
You can do a hot deck roof in any climate. And even if you couldn't (you can) you could do vented/ air gapped assembly.
I just dealt with a structure (up north) that had an air gap assembly and foam insulation. Not a fan, but I'm also not that familiar with their insulation techniques and it may be 100% valid up north... Had they used OSB for the air gap, would have been fine.
