My D3 dozer has some steering issues and need to find a hydraulic test kit which will work. I have two fittings which are STOR Boss fittings (7/16-20 and 9/16-18). Some of the kits found are 9000 psi others 8K psi. Currently have gauges for 400 and 2000 and the D3 does not use that high of pressures.
Pulled one of the fittings and thought about drill and tap for 1/8 NPT but after measuring, figure this would be a no-go due to how much side wall would be left once tapped.
Found kits from under 100 (china) to over $2K. Like good tools but cannot justify spending 2K for this job. Good thing with the kit is it will have quick connect for gauge
Anyone have any suggestions on kits?
