Hydronic heat safety switch
gayler
Lakin Kansas
My system was put in nearly 25 years ago by a company that was new to hydronic. There were several things designed wrong. One is the lack of a safety to turn off the gas in the event of pressure loss in the system. I would like to add something to turn off the gass if the heater loses liquid due to a leak. What would be needed for this? I’m running a 50 gallon natural gas water heater. I’m assuming a pressure switch to control a solenoid valve on the gas line?
u3b3rg33k
Boiler low water cut out (LWCO) controls are a pretty common thing.
Mine won't fire at all until it's over 7.3 PSI, and won't fire at full rate until it's over 13 PSI.
PWC Repair
Arkansas
Mine is a low pressure switch tied into the low voltage thermostat controls. If it gets below 5 psi (closed loop liquid loss) it opens the circuit so no matter what the thermostat tries to do.....nothing will come on.
fitter30
Peace Valley,mo
Are you questioning a boiler or a stand alone water heater?
Hot water boiler above 400k btu's low water cut off is required. If its a water coil or tube it's protected by flow switch.
Stand alone water heater is protected by a relief valve set at 210°f and or 150lbs
Thermocouple protects gas valve from opening if pilot flame isn't detected. Being connected to city water or well if there is a leak the leak would be pressurised unless the water would be off and tank would drain and gas valve thermostat would also fail.
G
gayler
Lakin Kansas
50 gallon natural gas water heater. If the heater drains due to a leak wouldn’t the thermostat still fire the burner? This is a closed system with antifreeze and water.
G
gayler
Lakin Kansas
On a related note. My expansion tank is leaking. It is a 6 gallon tank, 50 gallon water heater, five loops in the floor and 1200sq ft garage. I’m not sure if I really need a tank that size. Is this the correct size for my garage?
PCustoms
VT
So?
I don't see a safety risk here
PWC Repair
Arkansas
Sounds a bit large. My system is almost just like yours. I believe my tank is a 2.5 or 3 gallon. You don't need a very large tank for the lower pressures of a small (ish) closed loop system. I only run 5-10psi pressure in mine.
G
gayler
Lakin Kansas
Thanks! That’s what I was thinking too. The company that did it used a six gallon tank and the biggest I can find is 4.5.
