HyperLite wiring / cable routing??
NWOhioChevyGuy
Buckeye Hill (Morenci, MI)
My shop (40x60x16) will have 10 Hyperlite high bay fixtures, 5 in each row. (Already purchased)
They will be wired on two switches, 6 towards the front & 4 towards the back of the shop.
These lights have a second cable for a dimmer circuit control, which I don't plan to utilize.
Can you simply cut these shorter? Or should I terminate them in the junction box with the power connections?
I don't plan to utilize the plugs with and outlet configuration, I will be putting in a cord grip for a cleaner look and hardwire them inside the ceiling box.
Taking the dimmer cable into the box would be by simply mounting a second cord grip and feeding it thru into the box.
dcg9381
Austin, TX
I have very similar lights. I installed plugs on all of them and outlets in the ceiling, but assuming this is a shop, you could cut and terminate them with cords set to your length. I installed plugs because I assumed I'd be replacing them, but 4+ years in, they are all still live.
I do wish I had installed a dimmer. They are "daylight" bright. Annoying in the evening with a beer. But requires another wire, right?
N
NWOhioChevyGuy
Yes, it requires a separate set of wiring for the dimmer circuit and their special dimmer switches / controls.
I may look into the dimmers closer, but didn't plan on utilizing them.
Understood on the beer drinking light levels !!
cybrdyke
USA
You can just cut the dimmer cord, but remember that the driver will still be pushing 10VDC down it. Definitely not dangerous, but you might wanna tape it off.
N
NWOhioChevyGuy
Follow up question; Dimmer specifications states "Rated for upto 700W"
So each dimmer will only run 3 lights?
I may run just one dimmer on two lights and have the other 8 just on off.
For the low light desired situations, like mentioned above.
cybrdyke
USA
That's right, 700w max on the 120v side of that dimmer. That's pretty low. There are other manufacturers out there that go up to 1200w, like Eaton's SF10P. There might be some that are even higher.
But you said you were gonna cut the dimming cables down. You're gonna need those to dim these lights.
CD
wyliesdiesels
Modesto, CA
mm08822
I'd rather overlight the space and use a dimmer. When it's surgery time, it's all there ready to go.
